- Pc not starting.monitor light blinking
- Bandlab for pc - Download - Musical production
- Need for speed most wanted 2005 pc - Download - Racing
- My cute roommate pc - Download - Adult games
- Need for speed most wanted 2012 download pc uptodown - Download - Racing
- Acer keyboard light - Guide
R2D2_WD
Monday September 1, 2014
155
Feb 15, 2017 at 03:43 AM
Hi 122heya,
Could you please tell me what happens when you turn on the PC? Is it as if it is still shut down? I can you hear the cooling fans spinning? If the PC cannot turn on normally, most probably there is a power related issue. I would recommend you to test the PC with another power supply unit. If the PC is properly powered, you remove the RAM and no sound comes from the motherboard, there may be a motherboard issue. In that case, I would recommend you to seek assistance from a technician.
Hope this helps
Hope this helps
Feb 15, 2017 at 07:39 AM
