Problem with VB more than 10
- Problem with VB more than 10
- Vb editor download - Download - IDE
- Vb code download - Download - Source code editing
- Vb code maker aljzazy - Download - Other
- Vb net select case - Guide
- Vb round up - Guide
rizvisa1
Thursday January 28, 2010
766
Feb 19, 2010 at 08:07 AM
Could you provide the data that you are using to test and expected result. May be put the sheet at some share site with you test data and expected results like https://authentification.site
I am not clear on your loops like For r = 10 To 10
yeah sorry i was just looping it along one row to try and figure it out.
i am going to make it into a much larger data base search program with alot more search criteria so thats why i was lopping it round some and not others.
https://authentification.site/files/21018150/Search_prog.xls
rizvisa1
766
Feb 19, 2010 at 09:01 AM
You have declared S() to be of type string. So it is doing comparing a string with a number and hence your issue
you can do some thing like that
If (IsNumeric(s(x)) And IsNumeric(Cells(r, col(x)))) Then
If CDbl(s(x)) >= CDbl(Cells(r, col(x))) Then
Worksheets("sheet2").Range(inputy(x)) = 1
End If
ElseIf s(x) >= ws.Cells(r, col(x)) Then
End If
Also by the way "tues" and "Tues" also failed on test (case issue of letter T)
End If
End If
