Sound problem after upgrade Vista
kellz
Nov 2, 2008 at 05:18 AM
yashmaur Posts 14 Registration date Tuesday April 15, 2008 Status Member Last seen May 29, 2009 - Nov 2, 2008 at 05:26 AM
- Sound problem after upgrade Vista
- Sound picker - Guide
- Fx sound - Download - Other
- Beeping sound pc - Guide
yashmaur
5
I would suggest you to unistall vista and put back whatever OS you had at first hand. Then install the driver that where compatible with your OS. Vista is good but has some bugs, that makes it incompatible with some other programs such as drivers and other peripherals. Try using OS like Windows xp, it's better for your laptop.
