Seperate column into 2 parts with ordering
Carman
Jul 16, 2010 at 04:10 AM
venkat1926 Posts 1863 Registration date Sunday June 14, 2009 Status Contributor Last seen August 7, 2021 - Jul 16, 2010 at 06:49 AM
- Seperate column into 2 parts with ordering
- Tentacle locker 2 - Download - Adult games
- Fnia 2 - Download - Adult games
- Euro truck simulator 2 download free full version pc - Download - Simulation
- Plants vs zombies 2 pc download - Download - Strategy
- Red dead redemption 2 free download - Download - Action and adventure
venkat1926
811
I have added two criteria ranges H1 to I2 and K1 to L2.
see this in this modified file "1 carman.xls" and download it from the following url
http://www.speedyshare.com/files/23399124/1_carman.xls
the result you can see in sheet 2
the macro "test" is in vbeditosr but also given below
Sub test() Dim r As Range, crit1 As Range, crit2 As Range Dim dest1 As Range, dest2 As Range, r1 As Range Worksheets("sheet2").Cells.Clear Worksheets("sheet1").Activate Set r = Range(Range("A1"), Range("A1").End(xlDown).Offset(0, 1)) Set crit1 = Range(Range("H1"), Range("H1").Offset(1, 1)) 'MsgBox crit1.Address Set crit2 = Range(Range("K1"), Range("K1").Offset(0, 1).Offset(1, 1)) Set dest1 = Range("A1").End(xlDown).Offset(5, 0) Set dest2 = dest1.Offset(0, 4) r.AdvancedFilter action:=xlFilterCopy, CriteriaRange:=crit1, CopyToRange:=dest1 r.AdvancedFilter action:=xlFilterCopy, CriteriaRange:=crit2, CopyToRange:=dest2 Set r = Range(dest1, dest1.End(xlDown).Offset(0, 1)) r.Sort key1:=dest1.Offset(0, 1), header:=xlYes Set r1 = Range(dest2, dest2.End(xlDown).Offset(0, 1)) r1.Sort key1:=dest2.Offset(0, 1), header:=xlYes r.Copy Worksheets("sheet2").Range("A1") r1.Offset(1, 0).Copy Worksheets("sheet2").Cells(Rows.Count, "A").End(xlUp).Offset(1, 0) Range(dest1, Cells(Rows.Count, "A")).EntireRow.Delete End Sub
