Sound problem + Slow PC + BSOD
qwertysad
Wednesday September 8, 2010
Sep 8, 2010 at 06:34 PM
Blocked Profile - Dec 21, 2010 at 12:46 AM
- Sound problem + Slow PC + BSOD
- Microsoft store download for pc - Download - App downloads
- Bandlab download pc - Download - Musical production
- Nfs most wanted (2005 mod download for pc) - Download - Racing
- Fc 24 download pc - Download - Sports
Mattie
Friday July 23, 2010
12
Sep 8, 2010 at 10:48 PM
The computer makes a clattering sound and the sound persists.
One of the fan motors (either in the power supply, the case, or the CPU) is malfunctioning.
The fan needs to be immediately replaced. If it's the power supply fan, then install a new power supply.
The CPU fan is hitting a cable or a wire.
The obstruction must be removed immediately. The fan will stop working and/or whatever it's hitting will be destroyed. If the CPU fan stops working, then the processor will overheat and fry.
Follow these steps and you'll have your computer purring like a vintage Porsche (or whatever your dream car of choice is). And the best part? Maintaining your computer is a lot less messy than an automobile. You don't even have to roll up your sleeves.
Clean up disk errors (Run once a week)
Whenever a program crashes, or you experience some power outage, your computer may create errors on your computer's hard disk. Over time, the errors can slow your computer. Luckily, the Windows operating system includes a Disk Check program to check and clean any errors on your computer and keep it running smoothly.
Remove temporary files (Run once a week)
Your computer can pick up and store temporary files when you're looking at Web pages and even when you're working on files in programs, such as Microsoft Word. Over time, these files will slow your computer's performance. You can use the Windows Disk Cleanup screen to rid your computer of these deadbeat files.
Rearrange your data (Run once a month)
Don't be shocked, but your computer can get sloppy. Your computer often breaks files side by side to increase the speed of access and retrieval. However, as files are updated, your computer saves these updates on the largest space available on the hard drive, often found far away from the other adjacent sectors of the file.
Make Internet Explorer run faster
The Web is a sparkling achievement of modern society. It's everywhere--from the home to the classroom. We use it to communicate, to work, to play--even to waste time when there's nothing else to do.
Sep 9, 2010 at 04:53 AM
Is it really my fan? My laptop runs quit whenever i'm not listening to anything on it. The fuzzy noise only happens whenever I try to listen to something regardless from where the sound comes from such as the speakers or headphones.
Sep 9, 2010 at 04:55 AM
