Network Lan Connection Problem
Anonymous User
Dec 17, 2010 at 07:22 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Dec 19, 2010 at 07:35 AM
- Nfs underground 2 lan not working
- Tentacle locker 2 - Download - Adult games
- Nfs most wanted 2005 - Download - Racing
- Lan settings - Guide
- Nfs unbound free download - Download - Racing
- Lab 2 underground - Download - Adult games
Click on Start --> Run --> Type ncpa.cpl --> Press Enter.
"Network Connections" window will be opened.
In the menu bar, click on "Advanced" --> Select "Advanced Settings".
In the "Advanced Settings" window --> In "Connections:" section --> Select
your Lan card which is connected to the internet --> Click on the "Up Arrow"
symbol to move and make it as primary.
