Toshiba satellite L355-S7827 lap top power
firewater
May 9, 2011 at 07:54 AM
XevenSecond Posts 40 Registration date Sunday November 14, 2010 Status Member Last seen July 12, 2011 - May 9, 2011 at 06:48 PM
- Toshiba satellite L355-S7827 lap top power
- Toshiba satellite touchpad not working - Guide
- Toshiba satellite factory reset - Guide
- Power saving mode in computer - Guide
- Power bi download - Download - Data management
XevenSecond
5
im think is not software problem only they have another problem with hardware im think the RAM is not funtion or not stable if your computer is black only cannot open THE RAM IS ENFECTED AND DAMAGE TRY LISTEN: REMOVE THE BATERY FIRST, NEXT OPEN YOUR LOPTOP CAREFULLY REMOVE THE RAM CAREFULLY TRY TO CLEAN THE BRONZE TEETH USING ERASER CAREFULLY AND RETURNBACK AGAIN NOTE!!!! CHECK IF GOOD AND CORRECT AND OPEN YOUR LOPTOP IF ITS NOT WORKING AGAIN THE LAST ONE SUGGESTION TRY TO USE ANOTHER RAM AND CHECK THE HARDISK IF RUNNING OK
