PC Power supply problem
julesian
Monday October 24, 2011
Oct 25, 2011 at 04:09 AM
julesian Posts 4 Registration date Monday October 24, 2011 Status Member Last seen November 7, 2011 - Nov 7, 2011 at 01:30 AM
- PC Power supply problem
- Gta 5 download apk pc - Download - Action and adventure
- College brawl pc - Download - Adult games
- Minecraft java edition free download for pc - Download - Sandbox
- Minecraft bedrock free download pc - Download - Sandbox
- Bandlab download pc - Download - Musical production
Wednesday October 8, 2008
1,826
Oct 27, 2011 at 03:44 PM
this does sound like a power supply problem. Borrowing another PS is a good idea.
julesian
Nov 7, 2011 at 12:59 AM
Hello once again,
I borrowed a 600w atx power supply from my friend but the connectors for the hard drives are not compatible for SATA. I tried to put the 20 pin connector to my 24 pin on my motherboard. At least it seemed to work, but the hard drive has no power supply. I found a device that makes a SATA drive portable (USB + Power brick), I plugged the power supply part of the device and use it for a while.
After setting it up I can hear the SATA drive running but the monitor wont show anything.
Is my setup fine or can break the SATA drive? and how can I fix this problem?
Thanks!
Jules Ian.
Thanks!
Jules Ian.
julesian
i reseated the ram card and fixed the problem.
It seemed that my old 600w power supply has worn out, The new power supply worked fine.
