System problem
debnath - Apr 13, 2013 at 06:27 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Apr 13, 2013 at 04:38 PM
my system is on and i m working.but after sometime my system is shut down totaly.the problem is continuesly going on.
i do start another location,smps change,cable change.
i can't understand what i do
plz help me.
Make sure that the problem is not because of the overheating issue.
Open the cabinet --> Remove the dust --> Carefully remove the heat sink from
the CPU and clean the CPU Fan--> Remove the old thermal compound from the
CPU and from the heat sink --> Apply a little new thermal compound in the middle
of the CPU and place the heat sink back properly.
Make sure that you have removed the dust from the CPU Fan and Heat sink.
