Help Request - for Advanced Filter Macro VBA
evergreenX
Saturday September 26, 2015
Oct 2, 2015 at 08:50 AM
evergreenX Posts 7 Registration date Saturday September 26, 2015 Status Member Last seen October 8, 2015 - Oct 8, 2015 at 06:44 AM
- Help Request - for Advanced Filter Macro VBA
- Vba case like - Guide
- Submit request free fire - Guide
- Advanced systemcare - Download - Cleaning and optimization
- Number to words in excel without vba - Guide
- Request birthday change facebook locked account - Guide
rizvisa1
Thursday January 28, 2010
766
Oct 6, 2015 at 12:17 PM
without vba can you filter? I dont see any filter being applied in your vba
Oct 7, 2015 at 03:41 AM
Most likely this issue is due my limited VBA coding understanding.
Let me try to clarify more:
Interested Data Sections are 4:
1) MDB - Master Database (multiple lines row data with MDB header - 1st line row for the header and subsequent line rows for the row data)
2) AFD - Advanced Filtered Data (Multiple lines section where it is supposed to shows the final filtered result list - 1st line row for the header and subsequent line rows for the filtered data)
3) SI - Search Input (2 rows section where user has to input the wanted filtering criteria to have data filtered)
(1st row for the header and 2nd row for the inputs)
4) CB - Criteria Block for the advanced filter ( 2 rows section where Search input cells linked by a conditional formula as (IF(DY3="","*",DY3)).
The conditional formula purpose is to capture any inputted criteria from Search Input Section adding the wildcard (*) in case of blank cells left in Search Input Section.
NOTE: all four headers have equal name and format
ISSUE: same result showing all data from the MDB without any filter applied regardless same criteria are inputted in any cell of the SI section 2nd row.
Any suggestion/advice to progress?
thanks a lot for your help
Oct 7, 2015 at 12:00 PM
may be if you could record your macro and post it then it may make more sense
you can start the macro recorder. perform one set of operation and then stop the recorder
if you can make it work manually the way you want macro to work then may be it is doable, but recording the macro would show you a code that can be modified to suit more
