Sound problem in Labtop
Luis - Jun 15, 2008 at 12:29 PM
jmp59 Posts 29286 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 - Dec 15, 2008 at 07:07 AM
I have a Toshiba labtop model Satelite A45-S120 with Windows XP. It lost the sound. I have problems re-installing sound card drivers. The control panel does not have the System option for the installation process.
I need help.
jmp59 Posts 29286 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 249
Sep 27, 2008 at 05:04 AM
To re-install ur sound card u must
Download the driver for it
Unzip the file u get.
Run Setup.exe.
Click Next.
Select "Yes, I want to restart my computer now" and click Finish.
On the Toshiba support site https://uk.dynabook.com/support/drivers/ I don't find any driver for Satellite A45, but only for Satellite A40.
https://uk.dynabook.com/support/drivers/laptops/
I think it'll match.
I have a Labtop compaq presario
Pl suggest for the same problems
Regards
Parmanand
