Vaio VGN-CR160F sound problem
c2sP
Thursday July 2, 2009
Jul 3, 2009 at 10:45 AM
Joaquin - May 21, 2010 at 01:12 PM
- Vaio VGN-CR160F sound problem
- Chaturbate no sound ✓ - Internet & Social Networks Forum
6 responses
Thank you Pg, thank you Daldo, I tried doing both things but the problem remains. The only thing that seems to work is to disable/enable the driver a couple of times. I've read about people with this same problem in lots of forums but nobody seems to be able to fix it completely. It really is exasperating.
Dear sir,
I think that you should check your volume control settings! If you can't hear other programs sounds may be the volume is low or muted!!
c2sP
Jul 4, 2009 at 10:17 AM
Of course the volume is not muted and everything in the settings is supposed to be fine...
Open the Device Manager, select the "Realtek High Definition Audio" icon and delete it. Do not remove the drivers if the system asks to do it.
Restart the laptop and wait for its automatic detection.
This usually works until new Windows updates are installed.
I hope this will help you. Godd luck!
