Help, wireless card wont connect to my wifi
kayla23658 Posts 1 Registration date Thursday July 30, 2009 Status Member Last seen July 31, 2009 - Jul 31, 2009 at 04:18 PM
 Blocked Profile - Aug 1, 2009 at 02:32 AM
I have a somewhat old laptop i just got, and it has a wireless card. The wireless card finds my at&t router that i use for all my other computers but it wont connect. It says the signals 100%, but it doesnt fully connect to it, it just wont go on the internet. ?? can anyone help? its a Belkin wireless card, and my computer is a windows xp. thanks :)
If the Wireless Network is secured, you won't be able to connect,
I will advise you to enter the wep key to your wireless network settings on your pc
