Battery setting or hardware problem
nafee
Sep 8, 2009 at 03:53 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Sep 8, 2009 at 08:58 PM
- Battery setting or hardware problem
- Samsung hardware reset - Guide
- Assemble computer hardware - Guide
- Disable hardware acceleration - Guide
- Setting up a lan network - Guide
This is may be a problem with the charger!!
Verify if the charger cord is not damaged or something!!
Or just try using another battery and plug in the charger to see if the it's a battery problem
The battery indicator is a function of the HP software. You may have disabled this program or stopped the "service". I would download the latest hardware drivers from HP and load them.
