Sound card and Audio device
T2dawn
Jul 26, 2008 at 07:26 PM
jmp59 Posts 29286 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 - May 20, 2009 at 01:55 AM
- Sound card and Audio device
- Audio pitch and shift - Download - Audio editing
26 responses
I have the EXACT same problem you had in July and i was REALLY hoping that you found a free way to fix it? If so i would really appriciate it if you could tell me how to fix it.
Thanks,
Crystal
Thanks,
Crystal
jmp59
249
Dec 2, 2008 at 11:23 AM
Hello edison,
Plz tell the brand and the model of ur computer. Or of ur MB if it's a no-brand one.
I had the same problem for almost 2 months and today I accidentally fixed it. If in sound and audio devices volume tab it says no audio device and is grayed out where you can't click place icon on task bar then try this SIMPLE solution.
Go to: control panel
Go to: double click sound and audio devices>>place cursor in volume tab and scroll wheel on mouse and the grayed area changes, no audio device goes away and the name of your sound card appears. If this happens then it is fixed.
Now all you have to do is:
Go to: sound tab and voice tab to see if you need to scroll mouse for grayed area to change and sound card to come on. If you do the click apply and OK.
DON"T click apply and OK in the volume tab until you go to sound tab and voice tab. Click apply and OK in these 2
tabs and then volume.
Crutch49
Crutch49
hello is this that give u sound ? or to song ? i want sound to hear like songs ,games and like that . its this ?
jhondy
Saturday September 27, 2008
Sep 27, 2008 at 10:42 PM
were i can get sound card driver?
jmp59
249
Dec 9, 2008 at 09:33 AM
Start/Run. Type cmd + OK
On the black screen type chkdsk+ Entry.
On the 2nd lin u'll see a serial nummer.
Is this nummer u r searching for ?
hi,
yes i do have same exact problem,pls help me. what shall i do to fix this problem
regards
ricky.
regards
ricky.
jmp59
249
Sep 23, 2008 at 07:40 AM
u have to re-install ur sound card.
thank you for every thing , can i know from where are u ? Iam From United Arab Emarites And nice to meet u bro
jmp59
249
Sep 28, 2008 at 10:11 AM
I'm in France !
I don't understand "bro". What d0es it mean ?
maxmac
Wednesday October 15, 2008
Oct 16, 2008 at 06:20 AM
hi guys i have the same problem but when i did what was stated above it didnt work! also my device doesnt have the yellow explination mark or the red cross! i tried to search for the recovery manager as well and that didnt work either pls if anyone could help me.
thanx
thanx
sorry i was on an eco holiday hmmm how could i know the number or Id of the hard disk i ask my ferind but he say u must see the mother board i sow it but there was nothing , can u help me ? !!
jmp59
249
Dec 17, 2008 at 04:06 PM
What's ur problem ? Ur OS ?
And tell the brand and the model of ur computer. Or of ur MB if ur computer is a no-brand one
jmp59
249
Dec 17, 2008 at 04:18 PM
jmp59
249
Sep 25, 2008 at 05:55 AM
Hi ,
If u don't more have ur MB CD
Tell the brand and the model of ur computer. Or of ur MB if it is a no-brand one.
jmp59
249
Jan 28, 2009 at 01:55 PM
U have an audio device = sound card), but it's not installed. To install it u need a driver.
Tell the brand and the model of ur computer (for Dell, PB, Fujitsu, Medion tell the S/N)
If ur computer is no-branded, tell the name and the model of ur MoBo
Then I'll probably be able to give u a link to download the driver of this sound card.
I was recently given a computer, a dell from 2001? I installed Windows XP Home Edition service pack 1 and now, like all these ppl have no sound. I actually tried the scrolling thing, but as I thought, it did not work. From what I can from the one program you recommended, there is a SantaCruz sound card? but I have no idea how to get the sound to work. I have found many programs that all seem to be of no help at all afterwards. I keep getting messages saying that my sound card may be in use, and that I don't have an audio mixer installed. Please help, this computer is for my children to play games on....thanks!
Nov 29, 2008 at 07:36 AM
Jan 17, 2009 at 03:21 PM
i re instaled window [format].
thank you.
Jan 18, 2009 at 07:35 AM
Jan 25, 2009 at 07:46 PM
Jan 26, 2009 at 02:21 AM
*For Dell, PB, Fujitsu, Medion, the S/N.
