Sound Device Problem.
- Sound Device Problem.
- Blackberry device manager - Download - File management
jmp59
Tuesday June 8, 2004
249
Aug 25, 2008 at 03:37 PM
Hello !
Normal. After re-installing Windows u have to re-install your Audio card.
For that re-installation u need a driver which may be downloaded from the support site of the PC maker or of the MB maker.
What are the brand and the model of your PC. Or if it is a no-name one theese of your MB ?
