- Problems on laptops power switch
- Laptops overheating - Guide
- Android switch - Home - Mobile
closeup22
Friday May 15, 2009
2,099
Dec 11, 2009 at 06:48 AM
hi there,
the power switch button is damaged
you need to get this done by a qualified electronic technician
as when soldering ,if you miss something and the temperature is too
hot you will damage all the circuits and you will never know where is the faulty part
Dec 12, 2009 at 04:24 PM
One thing I forgot to say. If I keep the memory battery connected, the laptop never turns on. But if I put that battery out of motherboard, then it turns on. I'm talking about the battery which keeps safe the time and any other bios memory.
