Problem with my system restore
yahooz
Wednesday October 22, 2008
Oct 25, 2008 at 06:36 AM
rubrami281 Posts 164 Registration date Tuesday September 30, 2008 Status Member Last seen February 3, 2009 - Oct 25, 2008 at 06:58 PM
- Problem with my system restore
- Phison format & restore v3.26.0.0 ✓ - Pen Drive, USB & SD Card Forum
- System restore command prompt - Guide
- Disable system restore - Guide
- Restore deleted whatsapp messages - Home - Apps & Sites
- Recuva restore folder structure - Guide
rubrami281
104
Copy and paste the following link to your address bar:
http://www.download.com/3101-2001_4-0.html?tag=pop.software
Download AVGfree Anti-Virus and Malwarebytes Anti-Malware to your desktop.
Close IE....you don't need internet connection to run setups.
Disable Norton.........then run setup for AVG and Malwarebytes.
When they are both installed on your PC, run Malwarebytes full system scan. If infections are found, delete.
Now run AVG full system scan. Do same if infections are found. This should solve your problem. Remember, you should only run ONE anti-virus program on your PC at any one time. Running TWO can cause friction between the 2 programs. Personally, I run AVG(anti-virus) and Malwarebytes(anti-malware) on my PC. I was never fond of Norton.If you're still having problems after your scans. I would format my system back to it's original state..................Good Luck!!!!!!!!!!!!!
