No sound or sound icon
Mike - Jul 15, 2010 at 07:06 PM
 John - Jul 20, 2010 at 05:05 PM
Thanks for your reply. I opened the device manager as you suggested and I found yellow marks in front of: Multimedia Audio Controller and SM BUS Controller. I then went to the emachines site and to drivers. My choices were:
Chipset NVIDIA Chipset Driver (Packge) 4.50 35.4 MB 2009/10/20
CardReader eMachines Card Reader Driver 1.1 4.1 MB 2009/10/30
Modem Conexant Modem Driver 7.23.00.00 1.5 MB 2009/11/10
VGA NVIDIA VGA Driver 8.1.3.3 29.5 MB 2009/10/12
I didn't know what to do with these?? Please advise. I'm sorry to be such an amateur!
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 11,166
Jul 16, 2010 at 06:41 AM
This is the card for which you must check for updates for the drivers from the manufacturer's site:Chipset NVIDIA Chipset Driver (Packge) 4.50 35.4 MB 2009/10/20
Regards
Jul 16, 2010 at 06:27 AM
Dear Mike,
Please check whether the sound driver is properly installed in the Device Manager.
Thank you.
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020
Jul 18, 2010 at 11:55 AM
Sorry for the late reply.
If you failed to find drivers for your PC, then try this 1.
Just click on the below link.
http://www.emachines.com/support/options.html
Good Luck.
were you able to get this problem solved ? I'm facing the similar problem with Dell D520 ( windows XP ). Pls let me know if you were able to get this solved.
