EXCEL NEED HELP WITH GREATER THAN LESS THAN
prycek
Oct 14, 2010 at 10:06 AM
venkat1926 Posts 1863 Registration date Sunday June 14, 2009 Status Contributor Last seen August 7, 2021 - Oct 15, 2010 at 06:18 AM
- EXCEL NEED HELP WITH GREATER THAN LESS THAN
- Excel mod apk for pc - Download - Spreadsheets
- More than 1 if statement excel - Guide
- Kernel for excel repair - Download - Backup and recovery
- Arrow keys not working in excel - Guide
- Vat calculation excel - Guide
venkat1926
811
You have not indicated what is meant "etc". anyhow donwload the sample workbook from this webpage
http://www.speedyshare.com/files/24703195/prychek.xls
You can see the rank names and the points for each rank IN SHEET "ponts"
In sheet "rank" from A2 down type any number and see what happens
you can change the names of the ranks and their respective points in sheet "points" as you like
1. run macro sheet2.undo and
and then go to sheet 2 and type any number in any cell A2 down.
If you want to delete the entries and results in sheet "rank" you use the macro
"sheet2.undo"
both the event code and the macros are in sheet2 code
if you want to see these codes
1.go to vb editor (alt+F11)
2. hit control +R to get project window
3.in the project window go to this file (all open files names are there)
4.under your filename highlight "sheet2(rank)" and RIGHT CLICK THIS
and click "view code".
5. you will see both the event code and macros.
in the file I have sent in sheet "rank" already I have experimented with some numbers. you can continue and check.
If you change the entries in sheet "points" then run the macro "sheaet2.code" first and then start typing numbers from A2 down in sheet "rank"
your comments will be welcome.
"sheet2.undo"
