- Sound driver installation problem
- Dshidmini driver - Download - Gaming tools
- Ac97 driver - Download - Drivers
- Snappy driver installer origin - Download - Cleaning and optimization
- Spacedesk driver - Download - Other
Wednesday October 8, 2008
Jun 10, 2012 at 12:23 PM
Instructions
Things You'll Need:
* Driver and Application Recovery CDs
* Updated sound driver software
Check the Speaker Connections and Volume Control Settings
1. Step 1 Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound.
2. Step 2 Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray.
3. Step 3 Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
Perform a System Restore If Necessary
4. Step 1 If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs."
5. Step 2 Click on "Accessories," then "System Tools," then "System Restore."
6. Step 3 Complete the System Restore Wizard. If this doesn't work, read on.
Delete and Reinstall the Original Sound Drivers
7. Step 1 Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows, follow these steps.
8. Step 2 Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers."
9. Step 3 Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers.
10. Step 4 Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows system.
11. Step 5 Visit your computer manufacturer's official website. Check for any updated sound driver software for your sound card. If any, download them along with the installation instructions.
Things You'll Need:
Jun 13, 2012 at 05:06 AM
when i try to delete my Realtek High Definition Audio device the one having yellow exclamation mark it says error failed to uninstall device . the device may be required to boot up the computer
and for system restore it says there is no point for restore
and in device staus it says
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
plz help me
Jun 13, 2012 at 05:08 AM
and i have checked my speakers it is audible i other devices
