Audio problem in windown xp2
gafoormbnr
Wednesday September 26, 2012
Sep 26, 2012 at 12:40 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Sep 28, 2012 at 12:23 AM
- Audio problem in windown xp2
- Soundmax audio driver - Download - Drivers
- Ac97 audio driver - Download - Drivers
- How to change audio in kmplayer - Guide
7 responses
69
Sep 26, 2012 at 01:26 AM
Hi gafoormbnr,
I think I can help you with this if I know the Device instance Id of the onboard sound card in your machine. Reply to my post with the Device instance Id. Follow the steps below to get the Device instance Id for the internal sound card:
1. Right click My Computer icon on the desktop.
2. Select Manage.
3. Select Device Manager from the right pane of the window that opens.
4. Expand Sound, video and game controllers from right pane.
5. This will show the sound card in the machine.
6. Right click the sound card (with yellow mark) and select Properties.
7. Click details tab.
8. Select Device instance Id from the drop down list.
9. It will show the Device instance Id in a list box in the middle of the window.
Do reply with results.
2. Select Manage.
gafoormbnr
Sep 26, 2012 at 01:57 AM
instance id is:- HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_8086D608&REV_1000\4&3ACC46D&0&0201
gafoormbnr
Sep 26, 2012 at 07:22 AM
i sent instance id, but i did'nt receive any suggestion
gafoormbnr
Sep 26, 2012 at 07:26 AM
there was no problem earlier i recently formated the drive and installed windows sp2 sinnce then the problem arose all drivers from motherboard CD are installed except sound driver, (it is saying installing driver failed)
69
Sep 26, 2012 at 10:22 PM
Hi gafoormbnr,
Sorry for the delayed reply. From the Device instance Id (HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_8086D608&REV_1000\4&3ACC46D&0&0201) that you gave I found that you have a REALTEK sound card in your machine. You can download the driver from the following link (do select the appropriate operating system):
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Please revert for clarification.
gafoormbnr
Sep 27, 2012 at 01:42 AM
i received message "Realtek HD Audio Driver Failure" while installing the driver downloaded from the link u gave
(error code: 0xE0000227)
69
Hi gafoormbnr,
You can try this fix, it has worked in similar situations with error message (Realtek
HD Audio Driver Failure - error code: 0xE0000227).
Do you have Windows XP Service Pack 3 in your machine? If not, download Service Pack 3 from the below link. After you install Service Pack 3 you will see and additional option (Microsoft UAA Bus Driver for High Definition Audio) in Device Manager under System devices (see the link below for the image). Once this appears in the device manager, try installing the Codecs downloaded from Realtek website.
If you already have Service Pack 3 in your machine then disable Microsoft UAA Bus Driver for High Definition Audio in device manager and then rescan for hardware changes in the device manager. Install the Realtek Codecs now it should install correctly now without any errors.
Link for downloading Service Pack 3 - http://www.microsoft.com/en-us/download/details.aspx?id=24
Link for image of Device Manager after installing SP3 - https://seoroot.com/content-policy/
Hope this helps.
Hope this helps.
