Problems reading/using microsd card
johnnyf
Sunday March 17, 2013
Mar 17, 2013 at 10:22 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Mar 18, 2013 at 06:25 PM
- Problems reading/using microsd card
- Ps3 not reading discs - Guide
- Network card - Guide
- Fat32 sd card - Guide
- Activate o2 sim card - Guide
- T mobile sim card activation - Guide
69
Hi johnnyf,
Please follow the below mentioned steps and assign a drive letter to the SD Card from Disk Management Console and check if the Card is detected in "My Computer":
1. Click "Start" and type "Disk Management" in search box. Select Create and format hard disk partitions from the left pane.
2. Select and Right click the SD Card and choose on Change drive letter and paths.
3. A new window will pop. Click "Change" to change the drive letter.
4. Choose any letter of your choice from the available options -> click Ok. You will get a confirmation or warning dialog box. Click "yes" to confirm.
Do reply with results.
