Flash drive problem
GyuGeeGee
Saturday May 11, 2013
May 11, 2013 at 11:33 PM
GyuGeeGee Posts 4 Registration date Saturday May 11, 2013 Status Member Last seen June 4, 2013 - Jun 4, 2013 at 11:43 PM
- Flash drive problem
- Flash drive tester - Download - Backup and recovery
- Usb 4gb flash drive shortcut - Guide
- Snapchat flash not working - Guide
- Adobe flash drive download - Download - Other
- Google drive photos - Guide
carminabigue
Tuesday March 19, 2013
125
May 22, 2013 at 11:20 PM
If you can access the files, you may be facing a lack of permission to do more than that. You can check the permission level and change it to see if that give you full access to the drive.
1.Go to Computer
2.Right click your thumb drive
3.Click on Properties
4.Click the Security tab
5.Select Everyone and click the Edit button in the dialoge box
6.In the Allow column, check the Full Control box
7.Click Apply and OK
1.Go to Computer
Jun 3, 2013 at 10:22 AM
Click on the below link and follow the instructions
https://ccm.net/faq/4214-how-to-disable-write-protection-on-a-usb-key
GyuGeeGee
Thank you! Thank you! Thank you! :)
Jun 3, 2013 at 06:45 AM
