Problem formatting flash dive
boazoland
Friday October 5, 2012
Jul 1, 2013 at 09:47 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jul 1, 2013 at 10:18 AM
- Problem formatting flash dive
- Excel clear formatting - Guide
- Snapchat flash not working - Guide
- Adobe flash player apk - Download - Other
- Flash drive tester - Download - Backup and recovery
- Super smash flash 2 download - Download - Fighting
Try to format your pen drive using the format utility provided by the
Kingston.
Click on the below hyperlink "Format Utility". You can find all the instructions.
Format Utility
Note : The format utility is only supported on the DTHX30/XX
Kingston.
Format Utility
