Help With Major Excel Problem
nilnaij
Monday October 21, 2013
Oct 21, 2013 at 04:20 AM
TrowaD Posts 2921 Registration date Sunday September 12, 2010 Status Contributor Last seen December 27, 2022 - Oct 29, 2013 at 11:56 AM
- Help With Major Excel Problem
- Excel mod apk for pc - Download - Spreadsheets
- Kernel for excel repair - Download - Backup and recovery
- Arrow keys not working in excel - Guide
- Vat calculation excel - Guide
- Transfer data from excel to excel - Guide
5 responses
TrowaD
555
Oct 22, 2013 at 10:29 AM
Hi Nilnaij,
So Happy = Sad ?
I thought you wanted to single out the first word.
Turn:
ABC LTD
ABC PTE LTD
ABC PTE
Beijing Ltd
Beijing Pte Ltd
Beijing Pte
Happy Ltd
Sad Pte Ltd
Into:
ABC
ABC
ABC
Beijing
Beijing
Beijing
Happy
Sad
Could you give result as you would like to see it?
Best regards,
Trowa
So Happy = Sad ?
Turn:
ABC LTD
ABC PTE LTD
ABC PTE
Beijing Ltd
Beijing Pte Ltd
Beijing Pte
Happy Ltd
Sad Pte Ltd
Into:
ABC
ABC
ABC
Beijing
Beijing
Beijing
Happy
Sad
Best regards,
Trowa
TrowaD
555
Oct 21, 2013 at 12:09 PM
Hi Nilnaij,
Is it an idea to use find/replace. First replace (Ctrl+H) ltd with nothing and then pte with nothing. You could use an additional column if you don't like to mess with the original. Just keep in mind to SELECT YOUR COLUMN FIRST.
Best regards,
Trowa
Best regards,
Trowa
nilnaij
Oct 21, 2013 at 08:12 PM
Hi Trowad
I used the top example as a minor reference within my column I have other accurate names also which contains LTD and PTE
A7: Happy Ltd
A8: Sad Pte Ltd <-- These 2 are accurate so if I were to utilize ur method I might affect these correct columns too
The method im actually looking for is something to single out those cells that are similar without affecting those cells without any similarities
Thanks for the tip though! :D
A7: Happy Ltd
nilnaij
Oct 23, 2013 at 03:53 AM
Hi Trowa, Thanks for your earlier reply
I wana try to standardize
ABC PTE LTD
ABC PTE LTD
ABC PTE LTD
BEIJING PTE LTD
BEIJING PTE LTD
BEIJING PTE LTD
Happy Ltd
Sad Pte Ltd
I gave up on eyeballing for the similarities to change because I have 650k of Row, if there was a way I could identify all these cells at the same time and group them together so I can make the changes it would be so much easier. Like looking around with a partial cell match or smth.
Thanks man!
ABC PTE LTD
ABC PTE LTD
ABC PTE LTD
BEIJING PTE LTD
BEIJING PTE LTD
BEIJING PTE LTD
Happy Ltd
Sad Pte Ltd
Thanks man!
TrowaD
555
Hi Nilnaij,
Try this and see if it works (it works with sample data):
1)
Column A: Here are the company names.
Column B: This is a formula: =Len(A1). Drag the formula down to match column A.
Column C: Copy/paste company names here. Select column --> find/replace (Ctrl+H):
PTE with nothing
LTD with nothing
Space with nothing
2)
Select column A, B and C. Sort data:
Column C --> ascending
Column B --> descending
3)
Run the following code:
4)
Now you can delete columns B and C.
Best regards,
Trowa
1)
PTE with nothing
LTD with nothing
Space with nothing
2)
3)
Sub RunMe()
Dim lRow As Integer
lRow = Range("C" & Rows.Count).End(xlUp).Row
For Each cell In Range("C1:C" & lRow)
cell.Offset(0, -2).Copy
If cell.Value = cell.Offset(1, 0).Value Then
cell.Offset(1, -2).PasteSpecial
End If
Next cell
Application.CutCopyMode = False
End Sub
4)
Best regards,
Trowa
