Acer TravelMate 653 Laptop Power ON problem
- Acer travelmate b not turning on
- Acer keyboard light - Guide
- Acer erecovery management - Guide
- Acer bluetooth driver for windows 7 - Download - Drivers
- Acer factory reset - Guide
- Acer bios update from usb - Guide
Computertech
Friday February 6, 2015
893
Jun 24, 2015 at 03:27 AM
what is the reason you dismantle your laptop? without the knowledge you did not try to open this.. i think there may be any connection issues which cause this to happen.. i suggest you to contact a technician for this problem.
Jun 24, 2015 at 07:37 AM
Battery is charging as charging LED is showing.
I said I tried to open it but I didn't opened it.
But Thanks...
Jun 24, 2015 at 07:42 AM
If so then remove the battery
press power button for 48 sec
replace the battery
switch on the laptop
Jun 25, 2015 at 10:17 AM
Jun 28, 2015 at 12:08 PM
Jun 26, 2015 at 12:26 AM
connect the adpater directly to your laptop without battery and check if neither works .. contact technician.
