If i insert my usb flash drive my system not working
prasath
Nov 16, 2015 at 12:43 PM
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 - Nov 27, 2015 at 04:05 AM
- Usb flash drive gets hot doesn't work
- Usb flash drive tester - Download - Backup and recovery
- Usb 4gb flash drive shortcut - Guide
- How does a hard drive work - Guide
- Chipgenius usb flash repair tool - Download - Diagnosis and monitoring
- Hot potatoes download - Download - Education
7 responses
Ambucias
11,166
Nov 16, 2015 at 04:18 PM
So we don't repeat ourselves and waste your time and ours, what are the steps you have tried.
Ambucias
11,166
Nov 17, 2015 at 04:08 AM
After plugging in the device, go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again
Ambucias
11,166
Nov 17, 2015 at 05:21 AM
Try this:
# Download USB Fix
The numbers of analyzed and infected elements are displayed.
# Copy/paste the report here.
Tutorial : http://www.en.usbfix.net/2014/02/usbfix-tutorial-clean-option/
Ambucias
Moderator / Virus Security Contributor
# Download USB Fix
- Launch it, a shortcut will be created on your desktop.
- Choose "Clean" option.
- A pop-up will follow
Connect all your external data sources to your PC (Usb keys, sd cards external drives, etc...)
- Once you're ready, click "OK".
- While cleaning, you will lose access to your desktop, but this is normal.
Ambucias
Ambucias
11,166
prasath
Nov 17, 2015 at 04:04 PM
Does this occur with all usb memory devices?
Ambucias
11,166
Nov 17, 2015 at 04:51 PM
Hi
There are no doubt items that were transferred on that USB which are malicious, in the form of a worm. It is often the case when a Pen drive is used on another unsafe computer or being on Internet while the USB is connected.
The fact that internet stops and you can't work disk management is indicative of such issue.
USB Fix which I recommended to you is the most advanced tool to rid usb malware, if it did not fix it, nothing will.
I suggest that you only can find where your usb got corrupted. I also suggest that you do not try to run the same usb on onother computer as it may infect it.
Best regards
Best regards
Ambucias
11,166
Prasath
Nov 19, 2015 at 04:14 AM
Pen drives don't get repaired.
Ambucias
11,166
Prasath
Nov 19, 2015 at 05:01 AM
Flash drive and pen drive mean the same thing.
Ambucias
11,166
Nov 19, 2015 at 04:04 PM
Ambucias
11,166
Nov 20, 2015 at 03:59 PM
To show an image here, you must click on "Reply to this topic" then click on the image icon.
Ambucias
11,166
Pen drives cannot be repaired, just discarded.
Sorry
Sorry
Nov 17, 2015 at 12:39 AM
