Power cable problem
JessIcaspb
Thursday June 29, 2017
Jun 29, 2017 at 12:34 PM
Blocked Profile - Jun 29, 2017 at 12:47 PM
- Power cable problem
- Power supply cable types - Guide
- Media test failure check cable - Guide
When you say twist, do you mean the connector in the port, or do you mean twist the cavle like in the middle? If it is connecotr in port, you may try a new cable, but keep the receipt to take it back if it does the same thing. If you are twisting the cable in general, then yes it sounds like the cable has failed. once again, jist save the receipt in case you end up with the same result. Use a chain stire to purchase, like bestbuy, so that you will not get a restocking fee if you take it back. some pc stores will allow you to bring it back at a restocking charge added in!
