Sound problem
nick
Mar 7, 2010 at 01:02 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Mar 7, 2010 at 05:08 PM
- Sound problem
- Sound picker - Guide
- Fx sound - Download - Other
- Beeping sound pc - Guide
1,826
You probably have a faulty connection in the sound system and/or motherboard. It sound like this is a heat related problem, in that it fails after the laptop has reached maximum temperature. You could try to use an external laptop cooler to reduce the temperature.
