LAN and wireless connection problem
Neil
Aug 22, 2010 at 07:23 PM
dawooddoe Posts 404 Registration date Saturday February 21, 2009 Status Member Last seen November 12, 2010 - Aug 23, 2010 at 10:07 AM
- LAN and wireless connection problem
- Lan settings - Guide
- Wake on lan command - Guide
- Cs go lan - Guide
- What is lan card - Guide
dawooddoe
109
Maybe you did not configure the WAN/Internet setting correctly on router, that's why your laptop failed to connect to Internet via router. Recheck your WAN/Internet setting and if possible check the Internet status on router management page.
If you need more ideas, this is an example of wireless router configuration, feel free to take a look. Hope it helps.
