Help my sound !
Aceory1
Oct 27, 2010 at 04:46 AM
aquarelle Posts 7140 Registration date Saturday April 7, 2007 Status Moderator Last seen March 25, 2024 - Oct 27, 2010 at 01:56 PM
- Help my sound !
- Sound picker - Guide
- Fx sound - Download - Other
- Beeping sound pc - Guide
5 responses
aquarelle
491
Oct 27, 2010 at 05:50 AM
Did you download your driver on Compaq support website ?
Best regards
Best regards
I Used My MotherBoard Disk :(
aquarelle
491
Oct 27, 2010 at 06:18 AM
Try to find it on the compaq support website : http://www.compaq.com/cpq-country/cpq_support.html
What is written on the disk you used to install the driver?xp or vista?you can get the driver off compaq support website if still having issues,follow this link:
Hi there,
Other way is driver detective if all the other options do not work ,download it below on this link:
https://ccm.net/downloads/security-and-maintenance/4873-driver-detective/
Oct 27, 2010 at 11:46 AM
If you decide to use Driver Detective, remember that it is shareware. You will need to purchase a license to fully use it.
Regards
Regards
Ask a question
Thanks Guys But None Of These Have Solved My Issue Because On Compaq You Have To Enter The Name Of Your Pc And The Thing Is I Built Mine Myself And The Other Thing Is With Driver Detective It Gives Me The Same Driver As My Motherboard Disk Does And That Fails To I Will Be Willing For Someone To TeamView Me To Help Me Solve The Problem So If You Want To Teamview Me To Help Me Just Say ;-)
aquarelle
491
Every help need to be done on the forum because it could be useful to an other user then we can't use teamview. Have you try to reinstall or to update the motherboard chipset driver ? If not try to do it. After, reboot your computer and try to reinstall the audio driver, reboot again your computer and see if it is right or not.
See you.
See you.
