How to fix problem headphones
asirwad
Tuesday June 11, 2013
Jun 11, 2013 at 12:40 PM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jun 11, 2013 at 01:16 PM
- How to fix problem headphones
- How to connect bose headphones to mac - Guide
- Headphones not working on laptop - Guide
- How to use headphones with ps4 - Guide
- How to connect android headphones to iphone - Guide
- Acer headphones not working - Guide
If you are sure that your headphone is working properly then check the
Balance Level. If you are playing any audio or video file in the Windows Media
Player then check the balance level. Make sure it is set to 0 or the pointer
pointing in the middle of L&R. Also check the balance level in the "Realtek HD
Audio Manager". Click on the below hyperlink "Balance".
Balance
If the above image you can notice that the balance level user "Main Volume" is
set to middle between L & R.
Balance
