Removable Kingston Flash drive problem
pebbybay
Friday October 17, 2014
Oct 17, 2014 at 12:24 AM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Oct 17, 2014 at 03:26 AM
- Removable Kingston Flash drive problem
- Adobe flash player download - Download - Other
- Wd drive unlock - Guide
- Snapchat flash not working - Guide
- Virtual flash drive - Download - Encryption and decryption
R2D2_WD
155
Hi there,
Could you provide some details. What is the OS? Is this a new drive or it has been used. How are you trying to format it and why are you unable to do it?
Check if the drive is visible in Disk Management and try to format from there. If this is the method you have used and it failed, try formatting from the command prompt, using the diskpart command. Check below for details:
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/disk-pen-drive-cleaned-using-command-prompt-not/1402d6b4-4423-4642-ab6b-cded7d770128
Hope this helps
Hope this helps
