- XP Problem Wireless
- Windows xp sp3 download - Download - Windows
- Windows xp simulator download - Download - Other
- Verizon wireless activation number - Guide
- Windows xp sp2 download - Download - Windows
7 responses
movieguy250
Tuesday February 16, 2016
Feb 16, 2016 at 07:30 PM
Hi. I get a three-line response that disappears almost instantly.
Can't read it.
Can't read it.
movieguy250
Feb 17, 2016 at 06:56 PM
OK, I've got IP routing enabled No
Dhcp enabled Yes
Auto config enabled Yes
What am I looking for exactly?
Thanks!
Dhcp enabled Yes
Thanks!
Ask a question
movieguy250
Feb 18, 2016 at 07:29 AM
You meant IP, right?
IP address 172.20.20.20
Gateway 172.20.20.1
Subnet mask 255.255.255.0
Gateway 172.20.20.1
movieguy250
Feb 18, 2016 at 09:26 AM
OK, could you possibly state the problem in another way?
The only other number I see is DNS server 75.75.75
What can I do to connect wireless?
Thanks!
Thanks!
