Plugged in a usb wire to my pc problem
Person_73728828
Oct 25, 2020 at 07:03 PM
GeekPeek Posts 115 Registration date Tuesday June 30, 2020 Status Member Last seen June 30, 2021 - Oct 30, 2020 at 01:53 AM
- Plugged in a usb wire to my pc problem
- My cute roommate pc - Download - Adult games
- Bandlab for pc - Download - Musical production
- Need for speed most wanted 2005 pc - Download - Racing
- My cute roommate 2 pc - Download - Adult games
- Need for speed most wanted 2012 download pc uptodown - Download - Racing
GeekPeek
41
You probably caused a hard short circuit in the port.
Try to reset the power supply firstly. In most cases, just pull the power cable for 15–30 seconds and then plug it back in and try to boot up.
Otherwise you may have broken the port and have set up a permanent short. To fix that, open the case and disconnect the wires leading to that headset port. Repeat the power supply reset, and see if that works. If so, replace or permanently disconnect the damaged port.
If neither of those steps work, you may have a damaged motherboard of power supply. Do swap testing if possible, or take it to a service center.
https://www.minitool.com/news/computer-turns-on-and-off.html
