- Problem sound and audio device
- Audio pitch and shift - Download - Audio editing
- Blackberry device manager - Download - File management
hi,
this may be due to several reasons.
1. Make sure that the volume of your speaker are not down and check if the speakers are connected to the power supply.
2. Chexk the volume on the computer.
3. It may be that you do not have the audio driver, if so is the case, post the specs of your computer and then we will send you a link where you will be able to download the driver.
