Problem with Sound forge 9
Themask02 Posts 11 Registration date Sunday February 24, 2008 Status Member Last seen June 1, 2009 - Jul 6, 2008 at 05:59 AM
jenifer0703 Posts 22 Registration date Tuesday April 15, 2008 Status Member Last seen June 1, 2009 - Jul 6, 2008 at 11:06 AM
Hi
I am trying to install sound forge 9 on my system but each time installation is failing and saying that netpassport is require to continue installation
What is a netpassport?
jenifer0703 Posts 22 Registration date Tuesday April 15, 2008 Status Member Last seen June 1, 2009 9
To install sound forge you must let it download a netpassword from the internet to be able to use it or otherwise you will not be able to use the software re-launch the setup
It will also download a dotfx.exe this is not a spyware
I also use sound forge and i had to make the same process.
