Processor SMPS and fan problem
Debjit - 24 Aug 2009 à 07:15
 sibichan - 11 Sep 2009 à 00:46
Suddenly the processor stops working, SMPS is working fine but the fan shuts down and the fan at the back of the CPU cabinet shuts down.
What maybe the problem?
Debjit
24 Aug 2009 à 07:34
hi there,
you motherboard has a fuse blown somewhere
or the psu itself is not supplying power
change and replace with same wattage and volt
Remove your cmos battery and start the system. if it is working replace the battery with a good one. best of luck
