- 3945abg PRO/Wireless Problems
- Wireless network watcher - Download - Other
- Classicboy pro - Download - Console emulators
- Wireless personal area network - Guide
- Best wireless charger - Guide
- Mp3 rocket pro - Download - Music downloads
Solution to Intel(R) PRO/Wireless 3945ABG internet Connection problems. With Vista as your operating system. You can connect to the Network but cannot connect to the internet. The solution to this is to make sure you don't have the latest driver version dated November 2007 ver. 11.5. This driver is the cause for not being able to connect to the internet. You need to make sure you keep the older driver version. Dated: 08/08/2007 Version: 11.1.1.22. Install this version. Restart your computer. You try then to get into the internet and no success this is because you need to repair the network by diagnosing the problem then make sure that you reconfigure the IP Address which Vista gives you this option and once you have done this then VOILA you now have internet access.
