HELP. MY PC has no sound device
namu - Nov 6, 2010 at 10:09 AM
 Faizy - Nov 6, 2010 at 10:32 AM
My PC is acting practically as if it is oblivious of SOUND and AUDIO devices.
I have tried everything i can: reinstall PC, google solutions to solve my problem and find that there are many easy solutions that involve with desabling your Sound and Games Device under Device Manager<Sustem<Control Panel etc, tried to install the audio devices on the web but failed to encounter any success....
DOES anyone know the solution to my problem. Am I installing the wrong Audio Device? I tried Realtrek (recomended by many others) but FAILED.
is there a specific sound device that I have to install? If so, i tried searching for it...but i am so confzzled...there are a MYRIAD of devices? which one
and I tried to scan my PC (thrice) for devices that are missing or need updating, but found that non of them thought my PC needed a sound device update.
CAN SOMEONE please help meeeeee
my pc is an Intel (R)Pentium(R)4CPU2.8GHz 2.68GHz, 52Mb or Ram
and it runs on Microsoft Windows XP Professional, 2002 Version, Service Pack 3
thanks you so much
complettly Uninstall the driver you have installed and install the sound driver from your motherboad company website.
thats it.
