System Restore problem
- System Restore problem
- Bontel restore factory code ✓ - Android Forum
- Disable system restore - Guide
- System restore command prompt - Guide
- Phison format & restore v3.26.0.0 ✓ - Pen Drive, USB & SD Card Forum
- Restore deleted whatsapp messages - Home - Apps & Sites
Anonymous User
Nov 22, 2011 at 04:39 AM
Go to run and type
regedit and click ok
Navigate to this path
HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows NT\SystemRestore
On the right side
Delete following keys
Disable config
Disable SR
Restart,you should get back your system restore tab
On the right side
Disable config
Disable SR
Nov 22, 2011 at 05:36 AM
Nov 22, 2011 at 12:14 PM
