- Pentium 4 Flash player doesn't work? Help!
- Mumu player 12 - Download - Android emulators
- Fan xpert 4 download - Download - Cleaning and optimization
- Adobe flash player download - Download - Other
- Pluraleyes 4 - Download - Video editing
- Diablo 4 full torrent - Download - Role playing
Anonymous User
Nov 24, 2011 at 06:06 AM
Try this
Uninstall flash player with this
http://kb2.adobe.com/cps/141/tn_14157.html
Reboot your computer.
Download this
http://download.microsoft.com/download/1/7/d/17d82b72-bc6a-4dc8-bfaa-98b37b22b367/subinacl.msi
Create a folder on the desktop and save it
Download this
http://kb2.adobe.com/cps/494/cpsid_49419/attachments/reset_fp10.zip
Extract the reset_fp10.cmd.
subinacl.exe and reset_fp10.cmd files should be saved in the same location (folder) on the desktop
Double-click reset_fp10.cmd.
Do not use the machine while SubInACL is running.
When it is finished you will see "Press any key to continue".
Now go here
https://www.adobe.com/products/flashplayer/distribution.html
DOwnload and install it
Download this
Download this
Now go here
