Please help with my possible OS issue
- Please help with my possible OS issue
- Bliss os download - Download - Other
- Windows 10 os download - Download - Windows
- Mac os pipe - Guide
- Kali linux os download - Download - Linux
- Remix os player - Download - Android emulators
Wednesday October 8, 2008
May 24, 2012 at 06:15 PM
When Windows does a "disk repair" it can be an indication of impending Hard disk failure. Once in a "blue moon" is OK - "every so often" would leave me very anxious. When it deleted bad disk sectors it probably removed some Windows files. Hence your current problems.
I would get ready for that failure by backing up my data files to an external drive and making sure I had a Windows 7 install disk. I assume this Acer is like most laptops and does not come with a Windows Disk. There is probably a procedure for burning a Windows disk or an "image" of the hard disk. You should have done that when the computer was new. If you didn't, then you need to repair Windows first and then burn those backup disks.
You can download a Windows 7 repair image. It's an "iso" file that you can burn to a CD/DVD. Just double click on the downloaded file's name and Windows will offer to burn the disk.
https://neosmart.net/blog/2009/windows-7-system-repair-discs/
One you burn the disk(s) you change the boot device to you optical drive and boot from that disk. You then select the "repair" option and if you are lucky it should repair your PC.
May 24, 2012 at 07:21 PM
