Sound audio problem ..
mytch
Jun 19, 2012 at 06:12 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jun 19, 2012 at 08:23 AM
- Sound audio problem ..
- Sound forge audio studio 16 - Download - Audio editing
1) Click on the below hyperlink "Fix" and download the file
Fix
Double-click on it and follow the instructions.
[Note : If you are using Windows 7 then right-click on the downloaded file -->
Select the option "Run as administrator"]
2) If the problem still exists then reisntall your audio drivers. Go to your
manufacture's website and download the audio drivers.
Fix
