Audio problem
pinku
Jul 8, 2012 at 06:33 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jul 8, 2012 at 08:28 AM
- Windows media player cannot play the file because there is a problem with your sound device. there might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
- Audio pitch and shift - Download - Audio editing
- Soundmax audio driver - Download - Drivers
- Coagula audio - Download - Other
Click on Start --> Run --> Type services.msc and press Enter.
"Services" window will be opened.
Now at the right-side, scroll down for "Windows Audio".
Make sure that "Startup Type" is set to "Automatic" or else double-click on it
--> Set the "Startup type" as "Automatic" from the drop-down menu --> Click on
"Start" --> Click on OK.
If the problem still exists then reinstall your audio drivers once again. You can
download the drivers from the manufacture's website.
