Desktop icons were gone and the right click won't work
Katrina Sarangaya
Friday February 1, 2013
Feb 1, 2013 at 10:27 PM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Feb 1, 2013 at 10:58 PM
- Desktop icons were gone and the right click won't work
- Desktop goose - Download - Other
- Blackberry desktop manager - Download - File management
- Desktop zoomed in - Guide
- Docker desktop - Download - Virtualization
- Desktop shortcut - Guide
Feb 1, 2013 at 10:37 PM
Try the option "Refresh your PC".
If your OS is not performing well then you can refresh your PC without
deleting any of your personal files or changing your settings.
Follow the below instructions
1) Place the Windows 8 DVD in the drive and boot from it.
Make sure that first boot device is set to CD\DVD in CMOS settings.
2) When the prompt appears "Press any key to boot from CD or DVD..", just
press any key.
3) When the "Windows Setup", click on "Next:.
4) When the "Install Now" button appears, select the option "Repair your
computer", found at the bottom left side of that window.
5) When the "Choose an option" window appears, select the option
"Troubleshoot".
6) When the "Troubleshoot" window appears, select the option
"Refresh your PC".
Make sure you read "Here's what will happen" and then proceed with the
on screen instructions.
press any key.
"Troubleshoot".
"Refresh your PC".
Suzaku01
Feb 1, 2013 at 10:44 PM
I also had the same problem. And I didn't use a cd to upgrade my loptop , I just downloaded it and it's activator. What can I do now?
If you don't have a OS DVD with you then
1) When you switch ON your computer, start tapping the "F8" key to get "Startup Settings" options ( if boot menu appears, press "Esc" key and keep tapping the F8 key)
2) When "Startup Settings" appears, press the "F10" key.
3) When the "Launch recovery environment" appears, press the number key "1".
4) When the "Choose an option" window appears, select the option "Troubleshoot".
6) When the "Troubleshoot" window appears, select the option "Refresh your PC".
Make sure you read "Here's what will happen" and then proceed with the on screen instructions.
