Shortcut on flash drive problem
roro711
Sunday July 21, 2013
Jul 21, 2013 at 09:10 AM
baba_metca Posts 3 Registration date Friday August 2, 2013 Status Member Last seen August 2, 2013 - Aug 2, 2013 at 05:28 AM
- Shortcut on flash drive problem
- Flash drive tester - Download - Backup and recovery
- Usb 4gb flash drive shortcut - Guide
- At symbol shortcut - Guide
- Adobe flash drive download - Download - Other
- Snapchat flash not working - Guide
Jul 21, 2013 at 09:59 AM
There might be an autorun.inf file which is creating such an issue for you.
Follow all the steps given below
1) Disable the "Autoplay" feature. Click on the below link "Disable Autoplay",
and download the file --> Double-click on it and follow the instructions.
Disable Autoplay
2) Disable the "Autorun.inf". Click on the below link and follow the instructions.
First backup your registry. Click on Start --> Run --> Type regedt32 and
press Enter.
[If you are using Windows 7 then click on Start --> In search bar, type
regedt32 and press Enter]
"Registry Editor" will be opened.
Now backup your registry by going to "File --> Export" --> Save the file with
any name in your desired location.
Copy the text starting from "REGEDIT4" upto @="@SYS:DoesNotExist"
Open a "Notepad" --> Paste it --> Save the file as fix.reg
Note: Don't forget the extension "reg"
Now double-click on the fix.reg file and then click on "Yes" to merge it,
[Note : After following the above instructions, whenever you place any autoplay
CD\DVD all you have to do is go to "My Computer" --> Open the CD\DVD drive
--> You have to double-click on the setup file.]
3) Click on the below link and download the file "AutorunExterminator"
https://ccm.net/downloads/security-and-maintenance/5911-autorun-exterminator/
Extract it --> Double-click on "AutorunExterminator".
This will remove the autorun.inf files from drives.
[Note : AutorunExterminator need Dot Net Framework. If its not installed in
your PC then click on the below hyperlink ".NET Framework" and download it
.NET Framework]
4) Click on the below link and download the file "USBFix".
http://en.kioskea.net/download/download-24089-usbfix
Open the USBFix --> Click on "Deletion" and follow the onscreen instructions.
After completion of "Deletion" process, click on "Vaccinate".
5) Click on the below hyperlink "Malwarebytes Anti-Malware Free" and
download it.
Update it --> Perform "Full Scan".
Make sure you connect your pen drive also.
Disable Autoplay
press Enter.
REGEDIT4 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\IniFileMapping\Autorun.inf] @="@SYS:DoesNotExist"
.NET Framework]
download it.
baba_metca
Aug 2, 2013 at 03:25 AM
I have the same issue too, but no solution at the moment. It affected only the files, not the folders, nor the content in the folders. As well as something is trying to read or write on the floppy drive, but there is no floppy inserted.
Jul 21, 2013 at 12:14 PM
Jul 21, 2013 at 02:29 PM
Make sure that you have also followed Steps 1,2 and 3
Try the Step 5 and then run the USB Fix again. If the problem still exists then try in Safe Mode.
When you switch ON your PC, start tapping the "F8" key to get "Startup Settings" options ( if boot menu appears, press "Esc" key and keep tapping the F8 key)
Select the option "Safe Mode".
Thank you jack4rall
