Help! my laptop wont power on!
deo_g211
Wednesday September 10, 2014
Sep 10, 2014 at 03:28 PM
deo_g211 Posts 2 Registration date Wednesday September 10, 2014 Status Member Last seen September 10, 2014 - Sep 10, 2014 at 03:56 PM
- Help! my laptop wont power on!
- How to press # on laptop - Guide
- Keyboard wont type on laptop - Guide
Wednesday October 8, 2008
Sep 10, 2014 at 03:47 PM
The DVD drive has a small hole in the drawer. You take a large paper clip, bend the pointed end out and use it to poke into the hole. You can then release the DVD tray.
You might try to charge the battery for a few hours and then try to start it again.
deo_g211
Thankyou! I have already been charging it for the last 2-3 hours but nothing.
