Problems with my Acer Aspire NEED HELP
Skylersmama702
Tuesday September 8, 2015
Sep 8, 2015 at 11:07 PM
KY_WD Posts 2053 Registration date Thursday October 23, 2014 Status Member Last seen February 28, 2017 - Sep 10, 2015 at 11:00 AM
- Problems with my Acer Aspire NEED HELP
- Acer aspire 3 keyboard light - Guide
- Acer erecovery management - Guide
- Acer aspire 1360 - Hardware Forum
- Acer aspire one zg5 drivers - Software Forum
- Acer bluetooth driver for windows 7 - Download - Drivers
KY_WD
122
Hello Skylersmama702,
Your laptop is new and came with Windows 10 or the OS it's additionally installed and the laptop is old? If you have made recently upgrade to Win 10 I hope that you have made a repair disc before that.
If you haven't, try to find a Windows repair disk and to boot from it. If you don't possess CD I would suggest you to make a bootable USB on another PC and try to repair your system with it.
If you have the option, restart the machine into Safe mode. If it lets you into it, open the Command Prompt and enter the commands mentioned below followed by Enter each of them:
/FixMbr
/FixBoot
/ScanOs
/RebuildBcd
One thing more - check within the BIOS menu for storage and make sure that AHCI mode is enabled.
Cheers.
/FixMbr
/FixBoot
/ScanOs
/RebuildBcd
Cheers.
